Results 1 to 1 of 1
Thread: LB7 strange lope log
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default LB7 strange lope log
    Hey guys,
    Here's a log from the truck that has been giving me fits with this lope issue.... it lopes fine until you put in gear and then it idles up to around 750rpm and moves to the 800rpm column for fuel delivery...if I set the 800rpm column to 36mm3 at 0% throttle then it idles even higher, like it's trying to "escape" the lope.
    In this log you can see that DSP#4 (lope) it's idling high at 750rpm's but everything else seems to be right on.... when he switches back to DSP#3 the idle immediately comes back down to about 650rpm's...
    I tried flashing it back to bone stock, and even tried to limite the max rpm @ idle and it still does it... Any suggestions?
    Peace Through Torque
    www.PunisherPerformance.com
  1. LB7 Lope tune strange issue
    By LBZoom in forum Duramax LB7
    Last Post: January 4th, 2012, 11:39 AM
  2. Strange Log
    Last Post: December 3rd, 2010, 05:50 AM
  3. Lope at Idle
    By tdfchevy in forum Duramax LB7
    Last Post: February 28th, 2009, 07:47 PM
  4. Strange log file problem
    By JoshH in forum Diesel
    Last Post: November 2nd, 2008, 07:05 PM
Tags for this Thread
