Results 1 to 4 of 4
Thread: V1 requesting SES codes on a 2007 LBZ "response $23" and "routine not complete"
    Jul 2007
    Default V1 requesting SES codes on a 2007 LBZ "response $23" and "routine not complete"
    Hello all,
    I am trying to read the codes from my 07 LBZ with my V1 however it shows searching the available modules on the bottom of the screen but when it comes time to show any codes it tells me "response $23" "Routine not complete".
    This is my first time trying to use my V1 on the 2007 as I just bought it. I know there are codes as the SES light is on. I did select the correct ECM as well on the initial connect screen.
    Anyone ever run across this?
    Oct 2004
    The FlashScan V1 hardware does not support the LBZ (or other newer CAN based vehicles). To support the LBZ you will need to upgrade to the FlashScan V2 product.
    Andrew
    EFILive Crew
    The FlashScan V2 hardware does not support the LBZ (or other newer CAN based vehicles). To support the LBZ you will need to upgrade to the FlashScan V2 product.
    I think you mean the FlashScan V1 hardware...
    Oct 2004
    LOL. Damn 1 & 2 keys being side by side
    Andrew
    EFILive Crew
  1. Replies: 30
    Last Post: May 24th, 2017, 11:08 AM
  2. LBZ B1122 and "FACTOR"-smoke control
    Last Post: November 18th, 2009, 03:19 AM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. Cannot clear "B" DTC from LBZ with latest update
    By bballer182 in forum FlashScan V2 BB Logging
    Last Post: September 4th, 2008, 12:51 PM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
