Results 1 to 6 of 6
Thread: Error $0502 Script file not found
    Jul 2010
    Default Error $0502 Script file not found
    I am trying to flash a 2007 TCM (A40) with my V2 flashscan. I can flash the ECM without any issue, but when I try to flash the TCM I keep getting error $0502 script file not found. I have the latest version of V7.5 and V8. Anyone have any ideas what I am doing wrong?
    Oct 2004
    You need to go into the BBX configuration (in the V8 Scan and Tune application) and ensure that the A40 transmission controller is defined and selected (as your ECM controller will be already). Then once that is done click the Program button and that will copy down the necessary scripts for the A40 controller to your FlashScan V2.
    Andrew
    EFILive Crew
    Jan 2008
    I replied on DP also.
    Jul 2007
    If you have done the above and still have problems, read from post #60 here....
    http://forum.efilive.com/showthread....-release/page6
    the assumed summary is...
    • At some time in the past, the pass through reading of tune files did not populate the OS "magic number" in the tune file.
    • The pass through flashing does not need the magic number, as you choose the target controller at flash time.
    • The BBF process requires the magic number as it uses that to select the target controller and therfore the required script files.
    • If the magic number is not set ( is all zero's ) then the V2 can't find the matching script file and issues this error.
    The work around for this is...
    • Flash the new tune in to the controller using pass through flashing.
    • Read the tune back out using BBR.
    • Continue using the newly read tune instead of the older one.
    Simon.
    Jul 2009
    I tried the above and it still didn't work. I can read the tunes with BBR but every time I try to flash one back (even the one I've just pulled out) I get the 0502 Error (Script file not found)
    Quote Originally Posted by spandit View Post
    In S&T go into the BBX configuration, goto the F3:Tune tab, and under BBR/BBF Enabled Controllers setup a row for your ECM/TCM.
    What controllers do you have...?
    Post your Options.txt file.
  1. $050(something) script error or I'm just plain missing something
    By Wolfie in forum FlashScan V2 BB Logging
    Last Post: September 18th, 2019, 12:27 PM
  2. Error $0502
    By Webbs in forum AutoCal
    Last Post: December 9th, 2016, 07:31 AM
  3. How do I save a tune I made as a script file?
    By LBZoom in forum General (Diesel)
    Last Post: March 23rd, 2009, 06:14 AM
  4. cant select pids ini not found error message
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: September 3rd, 2008, 12:02 PM
  5. Tun file checksum error
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2005, 02:46 PM
