Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Newbie looking for advise with first tune
  1. #21
    Senior Member Dieselman's Avatar
    Apr 2010
    My understanding is.... Nothing for serial Wide Band data.
    For Analogue WB signals, you can average the analogue over a number of samples. The wording of the text is "Analogue/Digital" which reads to me (and many others) as Analogue <and / or> Digital, but it should actually be read as, Analogue "TO" Digital,
    Simon.
    Thanks Swingy. I changed it to 1 and it made no difference
    I did some logging and made a few changes today. How do I upload a log bigger than 2mb??
  2. #22
    Jul 2007
    Try compressing the file with Winzip or 7zip. You should get it down to about 33% of the original size.
  3. #23
    Apr 2010
    Ok went for a log today after changing my VVE slightly from a earlier log. This is the tune after the change and the log I got with it,
    Callie VVE setup 01.tun VVE log after 1st change.zip
    I then filtered andadjusted my VVE again. I went for another short drive and this is the result,
    Callie VVE setup 02.ctd VVE log after 2nd change.efi
    I don't know what I did wrong but the last log was going very lean
    I checked the WOT and it appeared ok. This is doing my head in to say the least
  4. #24
    Jul 2007
    It doesn't look too bad, Just remember to log for long trips to make sure everything averages out nicely.
  5. #25
    Apr 2010
    I just got a bit worried when I saw the AFR heading to 16.5:1 in the second log
    Is the second log ok or did I do something wrong with my VVE adjustment??
  6. #26
    Jul 2007
    It's probably just the VVE co-efficients going a bit off. What you can do it not the values in thos cells, and you know they need to go up a bit. So make your normal changes and after regening, see which way they moved. If they lower, or not sufficiently higher, manually kick them up and regen.
    Simon
  7. #27
    Apr 2010
    No worries I will look at that next time I change my VVE. How do I get rid of the negative corner on the map??? I tried a few things but it just doesn't look right
  8. #28
    Jul 2007
    I just manually change the values to make them more sensible. Just continue the curves of the VVE and flatten it out up over 6800 RPM, unless of course you have the limiter set higher.... In that case you need to use real data.
    Simon
  9. #29
    Apr 2010
    Hey Simon just a quick one - does raising the VVE figures richen up the AFR????
    Did you see my photo's of the plugs I pulled today. I might just make my whole table rich and work my way leaner. I don't want to fry my engine :(
    Ben
  10. #30
    Jul 2007
    Yes. Higher numbers in the VVE indicate that more air is flowing into the motor. This tells the ECM that more fuel is needed to keep the commanded AFR. so the ECM uses these figure to estimate the required fuel quantity for "stable" engine conditions. Varying load, RPM and throttle position will cause the dynamics to add/remove fuel and will alter the final AFR. This is why you need to run long "stable" periods to get the fueling correct.
    Simon
  1. First tune record - help a newbie
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: September 25th, 2010, 02:37 AM
  2. Advise required by newbie
    By SA1 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2007, 12:10 AM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
  4. Newbie Supercharger tune questions........
    By FreddyG in forum Gen III V8 Specific
    Last Post: June 19th, 2007, 04:11 PM
  5. Newbie with errors loading stock tune
    By vmax in forum Duramax LB7
    Last Post: May 16th, 2007, 12:07 PM
