Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Newbie looking for advise with first tune
  1. #11
    Senior Member Dieselman's Avatar
    Apr 2010
    I have the map up with the cell counts but when I go to the average value screen it is all zero's????
  2. #12
    Apr 2010
    Quote Originally Posted by swingtan View Post
    I should also add...
    • Try to keep a steady throttle when logging for tuning the VVE.
    • If you need to add / remove throttle, do so in a gentle fashion. No fast movements!
    • Get as much varying data as you can, hold it in first and take it up to 6000 RPM with very little throttle. Hold it in a higher gear and load it up. change up / down gears when cruising to mix up the data a bit.
    • Don't forget to filter the transient states out!
    • Get lots of data and apply, then log lots of data again.
    Simon.
    OK I will be nicer on the throttle
  3. #13
    Jul 2007
    It looks like you don't have the PID selections right and I think from memory that the default BEN map is incorrect. Try this...
    1. Open ScanTool with the log file of choice.
    2. Open the "PID's" tab or press <F8>.
    3. Under the "System" drop down box, select Calculated.
    4. Double click the "Ben Factor Bank 1, Serial Wideband, E38 Style" PID.
    5. Allow the program to re-plot the charts and maps.
    6. Open the MAPs tab or press <F11>.
    7. Go to your BEN map.
    8. Right click the map and then select "Map Properties".
    9. Select the "Data" tab.
    10. In the "Parameter" drop down box, select "(0) BEN Factor Bank 1, Serial Wideband, E38 style (factor ).
    11. Open the TuneTool with your current tune and go to B8101.
    12. Press <F2> to bring up the VVE table cells and then click on the grey box in the top left corner of the cell window to select all cells.
    13. Right click and "copy with labels" or press <SHIFT>+<CNTL>+C
    14. Go back to ScanTool
    15. Select the "Column" tab
    16. click "Paste Lables"
    17. Select the "Row" tab
    18. Select "Paste Lables"
    19. Select the "Cells" tab.
    20. Click on the "Constrain cell size" box so it is checked.
    21. Set the minimum width + height to 30 + 10.
    22. Select the "Empty" tab.
    23. Note that you can check the "Hide Empty Cells" box to remove data from the MAP. This can be used to "hide" cells with only a small number of samples and helps to remove random spurious data that can adversely effect the VVE shape. It's good to hide cells with less than 50 "counts", it's probably acceptable to hide cells with less than 10 counts. You can turn off the hiding of cells if you are working on a specific issue.
    24. At the bottom right, select "Save As" and choose a new name for your map.
    25. Select "Save"
    26. select OK
    You should now have a working map for BEN factor correction. If you want to compare maps between enabling and disabling the "hide empty cells, you can make two maps up and just switch between them.
  4. #14
    Apr 2010
    Thank you very much Simon
    The map works a treat. I hope you are ready for more stupid questions in the future though!!!
  5. #15
    Jul 2007
    always here to help
  6. #16
    Apr 2010
    OK time for another stupid question. When BBL how do you put BEN's in the PID selection???
    I looked through the list but could not find it
  7. #17
    Jul 2007
    BEN's are a calculated PID, so don't work directly on the V2. The data to produce the BEN's are still recorded on the V2 and you can then select them in ScanTool. Actually, I think you can "preselect" them in the BBL setup so they are there when you open the log in ScanTool.
    Simon.
    I just checked ...
    Open V8 Scan&Tune
    Select <F5> BBX
    In the "Selected PID Lists" window, select the controller / PID list you want.
    To the right of the "Selected PID Lists" window, click "V7"
    In the "Pre-Selected Calculated PID Names", add the BEN PID you need.
    You can also name the predefined dash page you want to use.
  8. #18
    Apr 2010
    Thanks Swingy It is all good now
    Cheers
    Ben
  9. #19
    Apr 2010
    Default BBX filters
    Hello everybody,
    What does the filter setup do in this screen shot???
    Thanks in advance
  10. #20
    Jul 2007
    My understanding is.... Nothing for serial Wide Band data.
    For Analogue WB signals, you can average the analogue over a number of samples. The wording of the text is "Analogue/Digital" which reads to me (and many others) as Analogue <and / or> Digital, but it should actually be read as, Analogue "TO" Digital,
    Simon.
  1. First tune record - help a newbie
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: September 25th, 2010, 02:37 AM
  2. Advise required by newbie
    By SA1 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2007, 12:10 AM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
  4. Newbie Supercharger tune questions........
    By FreddyG in forum Gen III V8 Specific
    Last Post: June 19th, 2007, 04:11 PM
  5. Newbie with errors loading stock tune
    By vmax in forum Duramax LB7
    Last Post: May 16th, 2007, 12:07 PM
