I have converted a 4wd with a 4l80e and L94 and want to have a tell tale light to tell me when I'm in power mode, does the LS1 ecu have an output to indicate when the shift mode is engaged or not?
nope... need to build a circuit to do it...
prob is that it is only a momentary switch that activates it and every time you key off and back on the mode reverts back to "normal" not "power mode"
E38's got to love them
E40's hate 'em
LS1's is there anything it wont work on
Holden VE SSV - GEN46L
www.ultimateconversionwiring.com.au
www.dualflash.com.au
Yes , that's the problem I have now that I'd like to overcome, I'm looking into momentary pulse relays
you might want to check www.the12volt.com it has all that stuff.
01 GMC Sierra 1500 SLE 5.3 cam swap
Tuned by ME (COS 5 - running strong and smooth)
