Results 1 to 7 of 7
Thread: What will happen if VE tuneed with wrong IFR data ?
    Lifetime Member wesam's Avatar
    May 2010
    Default What will happen if VE tuneed with wrong IFR data ?
    car is OLSD
    EFILive Tuner
    Jul 2007
    Assuming final AFR's are correct....
    1. If the error is linear across the pressure PIDs, then you can expect that the values in the VE table will be out by a similar amount. This may result in the VE values being "higher" than expected or "lower" than expected. In a manual car, this may have little effect but may have an effect in an auto.
    2. If the error is random through the calibration, then fueling will be very hard to get correct and AFR drifts may result.
    there may be more to it than this though....
    Simon
    May 2010
    What do you mean by AFR drifts ?
    EFILive Tuner
    May 2010
    and what if the error was not linear ?
    EFILive Tuner
    May 2010
    How could i take B3701 from this injector manual
    http://siemensdeka.com/specsheets/FI114991cs.jpg
    EFILive Tuner
    Jul 2007
    Quote Originally Posted by wesam View Post
    If the IFR is all over the place, the resultant AFR will most likely be all over the place as well.
    Point two above.
    You would need to take all the data and work out how it applies to the tables in B3701.
    B3701 is a 3d table of Injector delta pressure ( pressure across the injector ) and the battery voltage. So you need to create a new 3d table from the values in the link. At a guess ( and a big guess ) you can probably get away with FNPW_OFFSET and FNPW_OFFCOMP. however you'd need to understand the other data to make a better call on weather they should be used or not.
    Simon
    Jul 2005
    then you will 'bake in' all the error from IFR table into a VE table. since IFR table is referenced against the MANVAC, and the VE table is referenced against RPM and MAP (a MANVAC derivative), the IFR error can be fully 'expressed' with a VE table. however, this is not a healthy habit to get into.
    here's some old reading for ya: http://redhardsupra.blogspot.com/200...formation.html
  1. What will happen?
    By ferramento in forum Allison 5 & 6 Speed
    Last Post: February 26th, 2010, 11:27 AM
  2. why does this happen alot? -log reading prob
    By whackem04 in forum General
    Last Post: December 29th, 2009, 03:24 PM
  3. E-85,ifr ?
    By Lextech in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2008, 10:33 AM
  4. Replies: 2
    Last Post: July 13th, 2008, 01:08 PM
  5. Ifr ?
    By SOMhaveit in forum General (Petrol, Gas, Ethanol)
    Last Post: December 13th, 2007, 12:47 PM
