Results 1 to 4 of 4
Thread: Is there a AFR vs temperature setup yet?
Hybrid View
    Jun 2005
    Default Is there a AFR vs temperature setup yet?
    A couple months ago I asked about a table to compensate for temperature. When it is ccold the car would run leaner. With a 1000 hp pumpgas street motor I cannot afford to run lean. Did this ever get tested out yet?
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Oct 2004
    You're not thinking of the {A0014} "Open Loop IAT VE Multiplier" table in the V3 custom OS's are you. The values in that table are used as a multiplier to the VE table based on varying IAT temps.
    Andrew
    EFILive Crew
    Jun 2005
    I don't know. I believe Ross or someone was going to make a table a couple months ago. Is that it? I have been off for a while with the winter season.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Sep 2003
    Sounds like what you are looking for
    Open Loop IAT Ve Multiplier
    This table multiplies the values in the VE table based on intake temp.
    For example, if the VE Table value is 3.000 Grams*Kelvin/kPa, and the value in this table was 1.00 then the final VE number will be 3.000
    But if you entered a multiplier of 1.01 the value will be 3.000 Grams*Kelvin/kPa X 1.01 = 3.030 Grams*Kelvin/kPa.
    Larry - HumpinSS
  1. temperature vs injectors
    By fezz57 in forum Gen III V8 Specific
    Last Post: September 29th, 2010, 10:50 PM
  2. Fuel temperature affects mpg?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2009, 04:55 PM
  3. COS' temperature model
    By redhardsupra in forum Custom Operating Systems
    Last Post: October 5th, 2008, 11:13 AM
  4. charge temperature filter...
    By brokenfly in forum General (Petrol, Gas, Ethanol)
    Last Post: November 22nd, 2007, 07:40 AM
  5. coolant temperature
    By ws6togo in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:23 PM
