Results 1 to 10 of 17
Thread: Unable to get real-time data…
    New Member 09ZR1's Avatar
    Mar 2011
    Default Unable to get real-time data…
    I recently purchased EFI Live (version 7.5.6 139) for my ZR1 and although I have tuned with LS1 Edit, DSM link, and Pro Logic this software gives me a headache; not user friendly to a new user. Reading through the tutorials and the pdf’s I can navigate a little and see some of the normal basics taking place.
    The current issue I’m stuck on is getting any real-time information to display. Using the EFILive V7.5 Scan Tool with the V2 between it and the ECM I have connected to the E67 ECM, compiled a list of PIDs, and confirmed the support of the selections. However, using cntrl+m (or the yellow “monitor” button”) automatically makes the application go to “pause” rather than start the real-time display through the gauges or data (F9) list. According to the EFL Live documentations I should see the gauges moving at this point and be able to log, unfortunately its not working. Any help would be appreciated.
    Feb 2006
    Click the red button next to the yellow or "F3". That will start recording and you can view gauges or the line graphs.
    Mar 2011
    Quote Originally Posted by ChipsByAl View Post
    Thanks for the reply ChipsByAl. I clicked the Red button and although it acts like it’s recording, the gauges do not move and no updates show up in the Data tab. When I clicked “stop” and it asked to save the file, I saved it and even after replaying nothing shows up. It is frustrating for $800 :/
    You've made two post, both negative, do you want to 'learn' or just criticise something many others have no trouble using?
    Mar 2011
    I saw the email notification from a reply and grabbed the laptop and walked out the door with anticipation of success, only to get in the car and read your helpful “reply”. So to address your post, my answer is to Learn, with the forgiveness of being frustrated after 8hrs of no solution. I followed the advice and reported the results, I am wishful in thinking the issue is small. Expressing my feelings during this issue may be taken as negative, I give you that. However, your post is neither helpful nor insightful and is condescending at best. Neither my opinion nor yours changes the fact that to this point the experience has not been positive; a few pdf files of things going right is not enough for those new to the SW. Looking through the links I see quite a few people needing help with “simple” issues even after reading every document provide and spending many…many hours searching these threads. I am hoping one of them has experienced this.
    If you know a link or a case where this issue is covered I would really like to get that info from you. If you have some solutions to the problem that I have explained, I would really appreciate your experience. At this point I have used the documentation to the best of my ability and I am just stating the results hoping someone else experienced it. I assure you GMPX, when I get this all covered I WILL make a step by step for the next guy to avoid the frustration and I will not judge their initial reactions. With the knowledge you have, I am surprised you haven’t made one already or a Youtube showing the basics and possible problems experienced.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    The software has a learning curve no doubt, but hundreds (if not
    Thousands) of us have gotten though that curve. The way most of us learned is by using the searchbar on this forum. I'm sorry you are having
    Problems getting started, again.. Try using the searchbar on this forum, there are many tutorials written. I also think duramaxtuner.com has some
    Flash tutorials on getting started, but I'm not sure.
    Hope this helps
    -Kory
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jul 2004
    There is a scan tool tutorial under the help menu of the scan tool. Help->Tutorials->Scan Tool Tutorial. I wrote it a long time ago and have no idea if it will help, but it's worth a try. If it doesn't help, a private email to me will likely convince me to re-visit it and see if it can be improved.
    Ira
    Mar 2011
    Thanks for the replies guys. After trying every document and tutorial over and over, these are the steps I am following. See if these seem correct.
    1) Brought up EFILive V7.5 Scan Tool
    2) Connected the FlashScan to the OBDII and the laptop
    3) Turned the car on without starting the engine
    4) Clicked “Connect”, EFI Live did connect per the color/words at the bottom and in the Console
    5) Selected the PID file to open (with 24 supported PIDs in it)
    6) Started the car
    7) Clicked “Monitor” (or cntrl+m)
    a. Here is where the gauges should be moving and the Data list stats should show changes such as TPS% etc. Instead, the moment I click monitor the Data list changes 1x and now shows -40 F engine coolant, Timing -64 degrees, Engine flow 6000 Grams, etc. You get the idea. The readings do not move from there.
    b. After several reboots and FlashScan power offs and repeating steps 1-7 there was a brief moment where the tables started to change. The only correct stat was the Engine Coolant Temp which showed 172 F, but the throttle shows 87% at idle and Engine speed of 10000 rpm, and other really off stats (all at idle). I was able to log it for the few seconds it was happening, and then it went back to situation “a” above. Out of about 20-30 attempts it only happened the one time.
    I would be more than happy sending the log file to see if it works for you or shows up all crazy on the read outs. There is something wrong and it’s not that I didn’t read the documents, tutorials, tuning forums, or search for this situation in the archives.
    Do this:
    - File->Enter VIN and enter your VIN;
    - File->Select Controller and select your controller (is it an E38 or an E67);
    - press the green connect button;
    - Info->Validate PIDs;
    - goto PIDs tab, select pids (and save selection to file);
    - goto Dash tab, select/edit gauge/charts to show pids you selected;
    - click red record button;
    You're logging the wrong pids.
    Also, update your V7/V8 software and V2 firmware from here:
    showthread.php?15845-March-05-2011-release-candidate-2
    For updating V2 firmware you will need info from these threads:
    This is throwing you in the deep end but I am confident you'll swim.
  1. Silly real time logging question
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2008, 11:16 PM
  2. Spark tuning in real time....
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 18th, 2007, 10:15 AM
  3. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
  4. Live Real Time Tuning?
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 02:08 PM
  5. Real time tune ?
    By Clubsport R8 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2004, 12:13 AM
