Results 1 to 5 of 5
Thread: Can the 1-4 shift light be controlled on the e38s like the 0411 PCM?
    Jul 2003
    Default Can the 1-4 shift light be controlled on the e38s like the 0411 PCM?
    I can't find the calibration for it on the E38s... is it possible?
    With the LS1 pcm we can do it actually... Its awesome as a shift light...
    Jul 2007
    Well..... in my OS I have, B3314: Shift Light Minimum Throttle - Minimum throttle % allowed for shift light activation.
    So it looks like there is something there. That's the only setting I have though, so either there are missing tables, or the other settings are taken from different PID's. We would also need to work out the ECM pin that controls the shift light. It's a good topic though....
    Simon
    lol nevermind it's late and i got confused with t43.
    Jul 2007
    I was actually just thinking that maybe it's a CAN bus thing and it uses the BCM / Dash module to do the light? So many options......
    Jul 2003
    Ross can chime in... on the 0411 its controlled by the pcm when the pcm commands the 1-4 skip shift.. I am pretty sure its the same thing with this one.
  1. Shift Light
    By BRD-PREY in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2009, 10:16 AM
  2. Replies: 28
    Last Post: December 23rd, 2008, 02:22 AM
  3. Shift light?
    By traumadog in forum Gen III V8 Specific
    Last Post: December 4th, 2008, 07:10 AM
  4. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 05:56 AM
  5. shift light
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2006, 06:07 AM
