Results 1 to 4 of 4
Thread: Need table number for ute pwm fuel pump
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default Need table number for ute pwm fuel pump
    Been a while since I messed with a ute and can't remember the table number for the PWM controlled fuel pump.
    Help please.
    It's all good until it goes "Bang"
    Aug 2010
    Not positive on Holdens ... obviously I have never worked on one (given my location). Believe any that are equipped with a PWM variable speed fuel pump should have a subfolder called "Variable Speed Pump PWM" in the "Fuel System" folder. F0581 in a 2007 tune I looked at briefly.
    Regards,
    Taz
    Been at least 5 years since I've thought about that too. If I recall it was grouped in the Traction Control area, on the US vehicles the output on the PCM is tied in with the Traction Control, hence it's location.
    Best bet is to open up a sedan program and compare it to the Ute program whilst looking in the Traction area. I am sure I made a comment in the cals about the Utes using whatever cal it is for the fuel pump control.
    May 2005
    Ok found it, {B1904} TCS Delivered Torque Duty cycle.
    ** NOTE FOR HOLDEN APPLICATIONS **
    On VU Utes this output is used for the dual speed fuel pump module, it is known this module can slow the pump down at WOT, to eliminate this occurring , set this value to 100% which will make the pump always run at full speed.
  1. New fuel pump pids
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: March 12th, 2011, 09:47 AM
  2. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  3. Non TCC PWM transmission/converter in vehicle originally wth TCC PWM?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 17th, 2007, 07:15 PM
  4. fuel pump upgrade
    By ZL1Killa in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2006, 11:58 PM
  5. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
