Results 1 to 5 of 5
Thread: Can't connect to LB7 ecm
    Apr 2009
    Default Can't connect to LB7 ecm
    it will go through it 10 tries to check status and then gives me the status unknown msg. I've disconnected all aftermarket equipment and tried with and without highspeed and Alt keys enabled. I have a good connection and the obdII port appears to be functional.
    Ver 8.1.2 build 115 and 7.5.6 build 113
    Hi MM,
    You should update your V7/V8 software from here: March-05-2011-release-candidate-2
    After updating V8, also update the V2 firmware.
    Oct 2004
    Here are a couple of knowledgebase articles that relates to software and firmware updates:
    - Software
    - Firmware
    As Joe says get that RC2 release though.
    Andrew
    EFILive Crew
    Apr 2009
    Yeah I'll get her updated asap. I haven't got a chance to mess with the truck anymore.
    Apr 2009
    sorry it took so long to update you guys,,, after updated and trying a few more times i let the vehicle be over night. Went out and it connected with no further issues. I've had a few trucks do this to me from time to time and not really sure why but it no biggie now. thanks!
  1. LB7 ECM Read issues
    By Cougar281 in forum Duramax LB7
    Last Post: November 17th, 2011, 02:20 PM
  2. Cannot connect to lb7 ecm but can tcm
    By blewgrassmotorsports in forum Duramax LB7
    Last Post: February 11th, 2011, 04:04 PM
  3. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  4. cannot tune or connect to TCM in 03 lb7
    By fast03 in forum Allison 5 & 6 Speed
    Last Post: August 26th, 2009, 03:23 PM
  5. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
