Results 1 to 3 of 3
Thread: drive by wire help
    Dec 2009
    Default drive by wire help
    I have a 04 truck that is dbw. people say to use an 02 opp system but how do i get the etc to work ?? I'm running front mount turbo and COS3 . thanks
    Senior Member johnmaster's Avatar
    May 2011
    I am also curious how you would convert a DBW truck to cable? Not sure if that is what the OP is trying to do but I can think that it might make a few headaches but solve a few as well.
    For an 04 DBW truck use the 04 COS3 and dont change anything. Use another 04 OS if you have to so you can run a COS, but there are 4-5 COSs available for 04 PCMs.
    03+ trucks are all DBW so if you want to go to a DBC setup then you'll need a throttle body, PCM, TAC, and maybe a pedal assembly. Honestly not worth it, the changeover from the 99-02 512kb PCM to the 03-08 1MB PCM includes some other changes and I dont believe it is easy to run an 03+ truck on a 99-02 PCM (fans IIRC).
  1. 2002 drive by wire tune
    By s10mods in forum Gen III V8 Specific
    Last Post: March 24th, 2010, 01:11 PM
  2. help! convert to ETC/drive by wire
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 08:46 PM
  3. EFI Connection 24x Electronic TPI/LT1 Drive-by-Wire Throttle Bodies
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: May 26th, 2009, 01:52 PM
  4. Drive by wire motor
    By 91LS1S10 in forum Gen III V8 Specific
    Last Post: December 14th, 2008, 08:46 PM
  5. 97-98 remove drive by wire
    By v8vegaman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2007, 01:37 AM
