Results 1 to 10 of 17
Thread: Black Box
    Jan 2005
    Default Black Box
    No big deal, but I've had a couple of minor things with the black box.
    1) From the tuning tool: If the black box is not hooked up via USB when I open the tuning tool, the tuning tool opens in demo mode. If I hook up the black box, close then reopen the tuning tool, everything is fine. At that point I can unplug the black box.
    2) From the scan tool: I have 23 PID's selected and when I opt to download them to the Black Box, I get a message saying more than 24 PID's have been selected. I found if I select 22 or less PID's it will let me download with for high speed data logging.
    Sep 2003
    Some pids will use up 2 spots probably putting you over the 24 byte requirement. Dynamic air and dynamic cyl air are two of them
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Quote Originally Posted by Dirk Diggler
    Yea I was getting the same thing showed I only had 23 PID selected but showed I was using 28 channels. So I believe its not how many PIDS but how many channels you are using.
    Nov 2003
    For the record, I have the number one problem as well some of the time. Not a big deal, just a bit annoying sometimes to have to unplug the USB device, close the software, and restart the software.
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Quote Originally Posted by Drake
    If it kicks back to demo mode without the FlashScan box, there is something amiss with your registration details.
    Not sure if this has changed or not but in beta, we had to leave our contact/name information out. In the scanner, go to the registration screen and if you have anything in the name and contact fields, delete it.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Jan 2005
    SinisterSS
    I cleared my contact info and it didn't work. It's really not that big a deal. All I have to do is plug in the BB, start the program, then I can unplug the BB.
    EFILive
    I've got one for the wish list. Can the tuning tool be given some sort of automatic revision history? Every time I make a change to my tune, I first make a copy of the file, then go straight to the comments page and note what I'm changing. I was thinking something like this:
    PCM CALIBRATIONS
    .|_ OPERATING SYSTEM
    .|+ ENGINE CALIBRATION
    .|+ EGNINE DIAGNOSTICS
    .|+ TRANSMISSION CALIBRATION
    .|+ TRANSMISSION DIAGNOSTICS
    .|+ FUEL SYSTEM
    .|+ SYSTEM
    .|+ SPEEDOMETER
    .|_REVISION HISTORY
    .....|_21JAN2005
    .....|..|_LIST
    .....|..|_OF
    .....|..|_CHANGES
    .....|_20JAN2005
    ........|_MORE
    ........|_CHANGES
    Or some sort of log file associated with the tune that keeps a history of the changes made.
    Sep 2003
    Are you using the issue date on the blue card?
    Jul 2004
    Are you using the personal version?
    Jan 2005
    Sinister - yes
    John - yes
    Jan 2005
    John, I double checked one more time right after I posted just to be sure - and I had the day and month right, but the year was off by 1. Changed it and it works perfect now. :lol:
  1. SD on a black box OS?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: April 12th, 2009, 04:50 AM
  2. MAF off on black box
    By pullincrazy88 in forum Gen IV V8 Specific
    Last Post: March 21st, 2009, 06:44 AM
  3. V2 Black Box Logging
    By Blacky in forum FlashScan V2
    Last Post: November 4th, 2007, 10:51 PM
  4. V2 black box logging?
    By articSS in forum FlashScan V2
    Last Post: September 23rd, 2007, 04:57 AM
  5. is black box logging available on v2 yet ?
    By imtduncan in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2007, 12:11 PM
