Hi guys, back for more help. I'm putting a new engine in the Silverado, and since I'll have a complete exhaust (current engine has a busted exhaust bolt in the head, too deep to get at without pulling the head, too expensive to fix when a new engine was coming) I plan to use a wideband to do the VE table and tune the truck properly. I was hoping to see a sticky with a rundown of widebands compatible with EFI. What I did find was a lot of stuff that looked like I'd be having to build cables and stuff to install a wideband.
So the short question is, which wideband do I need to buy to do a proper VE table on my truck that would also be a plug and play setup with no cable making needed? Thanks.
