Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Auto Cal LLY Full Flash
    Lifetime Member bobo's Avatar
    Nov 2005
    Default Auto Cal LLY Full Flash
    Is it possible to full flash a LLY DSP5 tune into a truck using the Auto Cal as a stand alone? Is pass through full flashing enabled with v7.5 or V8? I've updated my software in V8 and V7.5 to the second release from March 5 2011. I can't get it to work at this point and I'm running out of ideas! Any help is appreciated.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Oct 2004
    AutoCal pass-thru mode is disabled i the V7.5 software. Right at the moment the only way to flash in a DSP operating system is by using your FlashScan V2. Once that is done the AutoCal device can be used to perform the ongoing cal-flash operations. So, it's nothign you are doing wrong.
    Andrew
    EFILive Crew
    Nov 2005
    Well that's not good. That will burn a vin unlock on my v2 and one on the Auto Cal. That's Alot of $$ to burn just to flash one controller. Guess I'll just use the auto cal to switch tunes on this truck.
    Nov 2005
    Could not get it to do serial DSP tune switching. I assume that's not available yet?
    What ECM? LBZ/LMMs dont and will not ever have that functionality, LB7/LLYs can do it with a V2 (and I assumed AutoCals).
    Nov 2005
    04 LLY- Autocal would not do it.
    Hmmm, I cant test it as I dont personally have a Duramax but I thought that was included in AC functionality. Did you set it up in V8 S&T -> BBX -> F4: Switch? Im shooting in the dark here, no idea if the AC can do it (be nice though).
    Nov 2005
    Yep. I named the tunes. V2 works and auto cal don't.
    I guess I will ask. Will the AC have the capability to do a full flash in the future?
    Custom Tuning Services
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    If not, my paper weight collection will be getting an expensive addition.
  1. Where's the Auto Cal
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2010, 05:30 PM
  2. Little help on full and cal flash on DSP tune.
    By Brian1 in forum General (Diesel)
    Last Post: March 15th, 2010, 05:41 AM
  3. Pre Full Flash to Full Flash Tune Question
    Last Post: January 13th, 2010, 12:43 PM
  4. Auto Cal out?
    By 98redorangeta in forum FlashScan V2 BB Logging
    Last Post: April 25th, 2008, 04:10 AM
  5. LB7 / LLY .cal file update - 08-Jan-2008
    Last Post: January 13th, 2008, 09:56 AM
