Results 21 to 30 of 32
Thread: Auto Cal LLY Full Flash
  1. #21
    Quote Originally Posted by stumpman750 View Post
    You shouldn't be releasing products out until they work the right way, when will the autocal full flash the lly.
    Just posted it tonight, here:
    http://forum.efilive.com/showthread....29-Mar-21-2012
    I had not seen the request for a matrix of which controllers are supported by which software etc.
    I will make one...
  2. #22
    Mar 2012
    I will make one...
    I'm sorry, that is Greek to me. All i want to know is will the autocal finally full flash my 2005 gmc lly?
  3. #23
    Yes, the software released today supports full-flashing LLY controllers (and LB7 and LS1) via AutoCal.
  4. #24
    Mar 2012
    My tunes are coming from bobo, from what they told me yesterday, whatever fix you guys have didn't work. They won't send me my tunes until its ready, is there anything you can send me confirming this fix will definatey work?
  5. #25
    You should really be getting this info from your tuner. I did tell Bob this afternoon that the RC10 release should not be used for LLY full-flashing.
    However, since then (i.e. tonight) I have released an update that fixes the problem with the LLY full-flashing.
    Your tuner will most likely see the update tomorrow.
    Then he will let you know what you need to do to get your AutoCal ready (if you have an AutoCal already). If he still has the AutoCal that you will be using, he will be able to configure it with the updated software before shipping it to you.
    FYI
    This RC10 version does not work for full-flashing LLYs:
    http://forum.efilive.com/showthread....10-Mar-11-2012
    This updated RC10 version does:
    These RC1 thru RC10 releases have all been "Release Candidates". I.e. they are not our official publicly released software. Once they have proven stable in the field, then we will make them the full public release.
    If you do not want to take any risks and you want to wait for a 100% rock solid guarantee that the software works, then you should wait until we release it publicly on our web site, here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    These RC versions are a courtesy to our tuners and their customers who can't or don't want to wait until it the software is proven stable and are prepared to take a small risk that the RC software will perform adequately for their needs.
  6. #26
    Mar 2012
    FYI
    Thank-you!, yes , I already have the autocal. For about a week now, not able to use. Getting in touch with my tuner, is impossible!, seems the help I'm getting from you has been far greater than what I have so far, what do I need to do, to get this autocal ready?step by step for dummys.
  7. #27
    Mar 2012
    Just talked to the middle man, and he's still telling me to wait. Any more info and testing to determine if it is working properly.
  8. #28
    Apr 2006
    The LLY autocal will hold single tunes for use until this DSP 5 is confirmed and publically released.
  9. #29
    Feb 2012
    If you have your autocal already you should be able to use it for single tune tuning in the mean time. I to am waiting for this release for my LB7. I got mine from Rob ^^ above and he helped me get mine goin. For now I hook it up and go to PROGRAM 1-5 whichever tune I want and it flashes it. You just won't be able to use your switch but you can still use the tunes just one at a time. Once the stable release is out I'll be updating mine (with robs help) and installing my DSP switch. If bob doesn't want you to install the release candidate then I'd wait man, don't want to take a chance and end up with a locked ECM or something. Its coming, they been working on this toooooo long to give up.
    03 Chevy LB7 Duramax CC/LB 4x4
    4" MBRP Straight Pipe
    EFI Live via Autocal tuned by Idaho Rob!!
  10. #30
    Nov 2009
    Just my .02.. you should send Bob a thank you note for waiting until he is 100% confident in the release and not sending you bogus stuff...some guys will screen the bang for the Buck, I congradulate Bob on being smart about it. He could use the option, however, of loading a single tune in it as Rob is...that works fine. Another thing...I'd recommend staying closely in touch with them VS posting up on the issue...seems your getting accurate answers from them..:thumbup:
    -Kory
    http://www.PPEI.com/
  1. Where's the Auto Cal
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2010, 05:30 PM
  2. Little help on full and cal flash on DSP tune.
    By Brian1 in forum General (Diesel)
    Last Post: March 15th, 2010, 05:41 AM
  3. Pre Full Flash to Full Flash Tune Question
    Last Post: January 13th, 2010, 12:43 PM
  4. Auto Cal out?
    By 98redorangeta in forum FlashScan V2 BB Logging
    Last Post: April 25th, 2008, 04:10 AM
  5. LB7 / LLY .cal file update - 08-Jan-2008
    Last Post: January 13th, 2008, 09:56 AM
