I have installed a pto switch to my ecm to use the cruise control switch to elevate idle in cold temps to keep the truck warm. after I reflashed my ecm to compensate for change in gear ratio, when I use the pto switch the engine hits the rev limiter until I turn it off. I checked the pto setting in my flash and it is set to 2200 rpm. What am I missing? by the way the only thing I changed is the gear ratio and speedometer pulses. Has anyone know anything about this?
