Results 1 to 4 of 4
Thread: passing Emission testing.
    Mar 2009
    Default passing Emission testing.
    The key to passing an emission test other that a clean burning and firing engine is to have catalytic converters in working order and running at exactly 14.7 AFR. i have just recently had to do a bit of mucking around to get my car to pass.
    First i had high flow cats went in for my test, had it all tuned within 3% on VE table but it was in CL mode anyway but it failed miserably.
    Next go i had standard cats back on and tuned it in OL then on the day just tweaked the AFR to be 14.7 using the live slider bar thing in the scan tool to get it to pass.
    My question is would it have passed in CL with the standard the cats? or does CL vary to much for the cats and out of there efficiency range of 14.7?? i would think it should just work since standard cars apparently pass it in CL. I wasn't willing to risk it at $165 a test when you cant change CL manually tho.
    Jul 2008
    What kind of cam do you have?
    If cam has sufficient underlap:
    CL with OEM cats, stock stoich AFR: passes.
    CL with hiflow cats: can get it to pass, may fail, may have to tweak some things (O2 switch points), need to watch out for NOx levels.
    Mar 2009
    LS3 with standard cam. ls1 computer cats etc.
    Joe- so high flow cats work at a different stoich? or just less lenient to error? with standard switch points in CL with high flow cats i was getting 100 Hexane and 300 NOx at 3000rpm and 100 hexane and 120 NOx at idel 800rpm.
    standard cats it was 30 hex and 5 NOx in OL.
  1. FI LS3 Corvette not passing readiness checks
    By Filmjay in forum Gen IV V8 Specific
    Last Post: March 1st, 2011, 09:54 AM
  2. Emission Testing/Ways to Cheat?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 07:08 AM
  3. 98 pcm reporting "not ready" at emission testing.
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: May 7th, 2009, 01:52 PM
  4. need some help emission related
    By 98SS2836 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2007, 04:32 AM
  5. Custom OS and OBD2 emission testing
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 02:10 PM
