Results 1 to 10 of 15
Thread: am i an idiot? how do you upgrade to COS on E40???
    Sep 2007
    Default am i an idiot? how do you upgrade to COS on E40???
    2005 corvette, shooting for 17 psi... gets pissed off after 5000, maf g/s maxed @ 512, rescaled 2 bar, all airflow limits raised (pretty sure) Applied MAF patch and fan patch, doesnt make any difference...???
    Member MadMaxHSV's Avatar
    Oct 2008
    512g/s is a hard limit on the e40 ecu. None of the COS patches fix this.
    Your only option is ditching the MAF and going full SD.
    General note on the patches, make sure you've done a full OS reflash, not just a calibration flash.
    Sep 2007
    i have done a full OS patch, so how do I do the full SD, this was my original question... link pleease....
    Oct 2008
    The patch doesn't do this for you, you have to manually fail the MAF. Read the AutoVE tutorial, its all in there.
    Sep 2007
    which autove tutorial? I have googled and searched, and the one for the LS1 appears to differ???
    Oct 2008
    ummm its the sticky at the top of this forum....
    http://forum.efilive.com/showthread....utoVE-tutorial
    You basically want to set the MAF fail frequencies C0301 and C0302 to always be out of bounds. I set both to '0'.
    The DTC MIL codes P0101, P0102, P0103 should be set to 'No MIL' to prevent the check light.
    Set the DTC Types for the same codes to 'C: Non Emissions'
    If switching to SD you will need to do a full VE table tune, so follow the tutorial. GelfVXR's notes in the thread above ammend the areas that are different on the E40 in the main tutorial.
    Sep 2007
    where is the info needed for 2 bar???
    Oct 2008
    All you get with the 2bar patch on the e40 is a boost VE table that allows you to MAP past 105kpa.
    I assume you have fitted a 2 bar MAP sensor and scaled it correctly?
    Sep 2007
    i have seen nothing for a 2 bar patch... map scaled to 188 & 62... never see anything over 105 kpa on any ve tables...
    Oct 2008
    If you've upgraded to the 2BAR COS properly you should have table A0001 Boost VE Table.
    Check the option to upgrade isn't still there on the 'Upgrade OS' tab.
  1. 2 BAR COS on E40 LS2
    By MadMaxHSV in forum Custom Operating Systems
    Last Post: July 21st, 2010, 08:53 AM
  2. COS for E40?
    By 1meangto in forum Gen IV V8 Specific
    Last Post: June 16th, 2010, 02:58 PM
  3. Fuel Problem COS-3 E40
    By Forcefedperformance in forum Gen IV V8 Specific
    Last Post: July 23rd, 2008, 08:23 AM
  4. Nitrous COS for 2006 E40?
    By KAZ MotorSports in forum Gen IV V8 Specific
    Last Post: May 23rd, 2008, 03:51 PM
  5. COS for E40 and fans
    By Alvin in forum Custom Operating Systems
    Last Post: February 18th, 2007, 09:10 PM
