Is it doable? I have the original FlashScan V1 and want to get a good wideband o2 that i can use in EFiLive. Thanks
01 Silverado ECSB:
6.2L 383 Stroker IB (6.125 Rods, 4" Lunati Forged Crank, 3.903 Bore -30 cc Lunati Forged Pistons, 222/219 .550 .547 116LSA Reverse split cam, double roller timing chain, hydraulic roller lifters, TEA port n polished heads, 7.400" Pushrods, ARP Bolts everywhere), 65lbs Injectors, ASP Underdrive pulley, 160* TStat, Dynatech LT's w/ Catted Y, Gibson cat back, K&N Cold Air intake, Flex a Lite Fans, 34" radiator, EFiLive Tune
I use the LC-1 with my V1 commercial scan and tune. you can't use the serial out, but you can wire it to the V1 using an analog input
Nice ok thanks fellas...Is there anything I need to do to it to wire it up or does it already come prefabbed and ready to plug into the V1?
01 Silverado ECSB:
LC-1 WBO2
Beautiful!!!! Thank you
Edit: Quick question...should the EFI Pin outs have come with my purchase? I bought it a looooooong time ago and never had those pieces in my kit. Aug 2005
01 Silverado ECSB:
Damn ok, yeah i never got those..I still have the original box and all of its contents but no analog connectors. I guess ill just have to bite the bullet and buy em. Thanks fellas youve all been a great help
01 Silverado ECSB:
Id send you mine but they are buried away in my parents house 300mi from me. Dang.
Hit up Ira at Fish Tuning, he'll be able to get them to you without the crazy Aus/Nz -> US shipping charges.
Awesome thanks!!
01 Silverado ECSB:
