Results 1 to 10 of 12
Thread: COS Newbee needs a little help
    Nov 2004
    Default COS Newbee needs a little help
    Ok, I've had EFI Live for awhile, but haven't had to use it for a year, or two because of being out of the country working. I have V1 Commercial Scan, and Tune with one license spot open, and I want to upgrade to COS 3 for my application. I'm following the tutorial, copy my existing tune, then open up the appropriate OS file for my application (04073003). Next, it says do a full re-flash to the PCM. But, since the COS file doesn't have any calibrations yet, the icons for the "read cal"; "write cal"; and "write full calibration data" aren't "live", meaning they don't highlight, or work. This is all without being plugged in to my PCM. Will these icons become "live" when I plug in, and turn key on, or am I doing something wrong? Thanks for the help.......................
    Those icons/buttons will become live when you plug into vehicle and turn key to on.
    Nov 2004
    That's what I thought!!! I didn't want to fool around with the OS, and mess something up, though! Thanks a TON!!!!!!
    Just out of curiosity, How long does the full re-flash take?
    Full flash on 0411 PCM takes about 2 to 2.5 minutes.
    Also, do Help->Register EFILive and enter the details exactly from your blue card.
    Also, update your V7 software from here: March-05-2011-release-candidate-2
    Nov 2004
    I did update to V7.5 Also, my serial#003523052397 when I plug in the cable, and look at "Flashscan VCM Licensing" reads "Commercial Scan and Tune", but when I look at "Register" (which I'm already registered"), it reads "Personal Scan and Tune"
    I pm'd Tech Support.
    Nov 2004
    Thanks. I haven't tried to do the full re-flash, yet. I have used the interface to make tune changes last time I used it, though. Thanks again.
    Oct 2004
    When looking at the 'Help->About' menu option in the tune tool with the cable disconnected (or not connected at the time the application started) should show as a Commercial scan and Tune, but will have a restriction to Personal Scan and Tune shown. The get the full-flash option enabled you need to have your FlashScan device connected to you laptop before starting the Tune tool.
    I have checked your serial number and it is known to our systems as a Commercial Scan and Tune licensed/enabled interface.
    Andrew
    EFILive Crew
    Nov 2004
    So, I'm good to go for the full re-flash for the COS 3, then, right? Thanks a TON guys for your timely help!!!
  1. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  2. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  3. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  4. Newbee Help!!!!!
    By mijdirtyjeep in forum Duramax LB7
    Last Post: March 24th, 2009, 12:41 PM
  5. newbee looking for some sample tunes
    By 03FullPull in forum Gen III V8 Specific
    Last Post: July 31st, 2008, 01:31 PM
