B1152 has been fixed as an out of range cell, I corrected it and set it to 80000. Doesnt matter in terms of when BTM will come in, B1149 makes sure it is never enabled, but it is important that the value is in a valid range.
Upshift RPMs are in Transmission Calibration -> Shift at RPM -> Upshift. Parameters D1127, D1128, and D1129. All set to 4800 in the tune you posted, I set the 1->2 and 2->3 to 5500 and 3->4 to 5200.
Hope this helps, you might have to play with the shift pressures if the truck bounces off the limiter at 5500 and doesnt shift for a second.
