http://phone-jack.org/rj11
Mine only has four wires.
I thought it was pins 2 and 5 on the RJ12 plug...
watchout, an RJ11 may or may not fit properly.
Running with just one NBO2: if motor runs rough, this indicates that VE and/or MAF are not correct (whichever one the ECM is calculating airmass from).
RJ11 Fits but wires are in the wrong spot and only 4 of them. Need to order an RJ12 cable. None of the local stores have, not even Radio Shack. I cannot believe I have to special order this thing.....Well, another week gone by.....no o2's and no word on the meter I sent to Innovate two weeks ago, for the 3rd time!
Phone cables can be misleading, the one that connects to the handset is 4 pins, but it is a smaller connector than the land line. Might be easiest just to get one from TAQuickness if you can't find the RJ12 connector and a 3 pair cable at your hardware store.
E85 is NOT flex fuel.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
Thanks. This info should help me locate what I need locally.
fuel trim log 3 29 2011 WITH TABLES.efi
This is the fuel STFT log per swingtan. This is as far as i got. Ben map??? What is a ben map and how do I create from this? Thanks guys. Judging by the pinned trims I need some fueling mods!!!!!
Thanks!!!!
Here is the tune....Any help appreciated.
You didn't get the serial wideband connection going...?
