Roger that.
I guess what I am trying to do is change a polynomial with a multiplier which is fine with me if it works. The above process will be for another day. Happy to take a run at it at a later time.
In the interim, I will be thrilled if I can get a ben map created to produce cut and pastable data with the LTFT's. I have them turned off now. I probably should turn them on, turn off STFT's (location?) and get this new ben map installed. Hopefully you all can help with that.
Looking at my file above its empty.
THanks!!!!!!!!!!!!!!!!!!!!!!
