Yes I have done that and my VVE is ok apart from a few cells that I just can't get 100% spot on. I was just going to have a play with this and see if it is quicker to get the VVE close while being in the safety of Closed Loop (I have changed the cam)
My factory tune was actually actually putting in + trims through the whole rev range. I have a Tech Edge WB for doing my WOT work. I have talked to Swingtan and realize that the STFT will only work during closed loop and if LTFT's are not disabled it could make the PE cells either rich or lean.
Hope this makes sense!!!
Ben
