Results 1 to 4 of 4
Thread: high idle help
    Apr 2009
    Default high idle help
    new at diesel, i work at a gm dealership (yeah for me lol) anyway we sold a company a cab and chassis in 03. the vechicle is back in the shop for repair.The resolution was a ecm, the problem is the truck had a valet/dsp2 switch added elsewhere. I am trying to get the high idle func back operating (is NOT equipped with cruise.) I have tried the dsp2 cust calibration-but there isnt a high idle table avalible for func #2.I am beyond brain fried here. I can not find in the tutorials for either adding a table or installing a valet switch. PLEASE HELP!The truck is a 2003 2500hd with 6spd manual, it has a added on muncie pto. I just need to get a high idle func on this truck! Thanks again...really any lead way help is greatly appreciated
    Apr 2009
    Default re- high idle
    or any thoughts on a valet switch and info on how to do so
    Mar 2009
    Does your replacement ECM have teh PTO function enabled in it? Without a cruise control switch you will need a PTO switch to raise the idle speed which will require an ECM cal with the PTO function enabled in it.
    Apr 2009
    Thanks for repling back THEFERMANATOR, yes I did have all of that set-up w/ tech 2 in pto functions. The problem was where the input for the switch was located in pin 31 c1 ground signal (like for dsp2) that is where previous installer had it, so I switched it to pin 71 or72 c1 and used a 12v input and works well. Just need a cool off period to rethink this thing out....would be awesome if v2 had a idle table for dsp.Thanks again for youre time and input.
    amiller406
  1. High idle after new MAF
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: May 2nd, 2011, 04:43 AM
  2. tune help, very high idle
    By BROKE in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 06:07 AM
  3. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 03:14 PM
  4. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 01:18 PM
  5. What's holding my Idle high?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2006, 04:08 PM
