My question is how do I change MAF voltage scaling in the PCM? I have read that some have had same problem im havin (p0108) code on a 2002 lb7 duramax and ive replaced all the sensors as others have stated and this voltage changing thing has been mentioned more than once. I have changed out the factory intake tube, put an 03-04 on my 02 and an aftermarket dry filter with a custom half open airbox.My truck is a 96 and i swapped in an lb7 so the factory airbox wouldnt work. any help is appreciated thanks yall
