Just after some help on the best way to set up Siemens 107961 60lb injectors into a E38 with 12619078 OS, the old injectors are 12569113 36lb.
B4001 injector flow rate has a max setting of 63lb in this OS.
In the past we have used multipliers but this is an A6 with a supercharger so really need to make sure I get things set up correct for calculated torque and have a VVE table that’s not to high or low as I don’t wont to help speed up the transmissions demise!!
Any input from tried and tested settings would be much appreciated.
