Hey guys new here and need some help. I'll try to be brief but cover everything. I was putting a DSP5 in a buddies LBZ. Broke the pin pushed it back out put a new pin on the wire tried to get it to set no luck. Got another DSP switch got the plug to set grounded it to the body and can not get the switch to change voltage in the PIDs when I run the scan tool.
I have tested the new switch with an ohm meter and it showed a change in ohms. I tested the ground with a light and it's grounded. I've even changed the ground to make sure it was grounded. The reason I didn't use the plug in the ECM is when I did my LMM I had a hard time getting to that hole and found it was easier to ground to the body, so I took the same approach.
I see where the new pin has come through the middle and felt the click as I pushed it in. I can not pull the new pin out like I could the old so this is telling me its in. I did push the pin out some thinking it may have been to deep but when I tried to push the pink thing back in it would go in then. So I pushed the pin back to where the pink thing slide all the way in.
I am in the second row third hole (46) to the right with the wider side of the pin towards the grey wire in 47. Looking at the plug from left to right with the bundle to the right there are two wires then the grey DSP a space then another wire.
The only thing I didn't do was disconnect the battery when I did the install would/could this be the reason I'm not getting a voltage change? Please help. Thanks
