Tonight I went to the track to try and run the BURB on the dyno and so I loaded in a dyno tune into my V2 and BBF flashed it in. The first time I went to flash it it wouldn't go through(Idon't rmember the error code, but I believe it was no response from ECM). I turned the key off and waited 30 seconds and retryed. This time it went through but took a long time during the initializing step before it finally began the flash. Once it finally began the flash everything seemed fine and went normal and started up afterwards. Afterwards I went to flash in my regular tune and it won't go through, says it is unable to unlock the ECM and gave me an error code($0614 I believe). Also I can no longer see any data when I go under the data logging and display data option for the ECM. The TCM reads just fine, but nothing from the ECM. I can read the VIN and CVN from the ECM, but nothing else. It still runs and drives, but I don't think my dyno flash went in correctly, and now it's all locked up. I'm running the latest public release and have made no changes to the software since my last flashes. And it won't read from the laptop either. Please help.
