Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: edge cts monitor
    Nov 2007
    I got it
    Bonus Features
    • Adjust EFILive™ Tuned PCMS on-the-fly
    On 2001-2005 LB7 and LLY Duramax engines you can now change the power levels on-the-fly created by your EFILive™ custom tuning software with your Edge Insight CTS! Simply use your EFILive™ software to change your DSP5 Switch Type from “hard wire” to “serial”. Once you are set up to support “serial” communication, simply use the up and down arrow buttons on your Insight to adjust EFILive™ tunes on-the-fly.
    Lifetime Member tokymon's Avatar
    Apr 2008
    yes just change to sierial works good on cts and cs monitors
    just buy the insight one though not the tuners
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Nov 2007
    The more I research this subject the more I like it !! My supplier sells the Insight CTS for $300 and the CS for $225
    I can sell a DSP 5 tune and a CTS for $600. No switches No wiring.......YEA Buddy !!
    Just keep in mind, it's not for the LBZ/LMM Bosch ECM's.
    Nov 2007
    Would it be too difficult to switch those on the data bus ?
    I already spent a long time trying to figure out how to, do but in the end the Bosch ECM beat us.
  1. Tire pressure monitor
    By sixltrbtr in forum Lounge
    Last Post: September 4th, 2009, 09:57 AM
  2. how to monitor boost?
    By turboolds in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 04:37 AM
  3. Readiness Monitor Question
    By Duramax 6.6L in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2008, 12:45 PM
  4. Best way to monitor clutch slip
    By robz in forum General
    Last Post: March 12th, 2008, 11:30 AM
  5. Keep Edge J/A or not?
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 11th, 2007, 11:44 AM
