Alright so I'm installing a TC-78 383 into my 96 camaro and I'm going with an EFI connection 24X ECM. I'm using D585 coils and a 01-02 (GM# 12200411) pcm. I'm wondering what I need to do to get this car fired up. I know the firing order is different and EFI connection is building me a harness that swaps the injectors/coils to compensate for this, but do I need to load a van tune into the pcm or will the stock LS1 tune work because the injectors/coils are already swapped? I have EFI live to load a base tune and I'm having my dyno tuner do all the tuning, but I need to have it at least run before I show up to the dyno.
