I can't find a pin assignment for Tach output on 2008 E38. Is there even an output available like pin#10 on ls1 pcm?
Aftermarket tachometer....
FLASHSCAN V2 & AUTOCAL
Hello GameOver,
If E38 Tach output is changed from serial data to crank (for aftermarket Tach), the output is supposed to be connector C1/X1/J1 (black) pin 48. I have never done this - just in a pile of R&D files I’m collecting.
Hopefully that is correct ……
Regards,
Taz
Thanks TAZ....Always helpful!
Depending on the Tacho, you will need to add a pull-up resistor to 12V on the output. 1K Ohm should do the job.
I have to double check but we always pulled a wire that was in the coil wiring harness to run a MSD window switch which required rpm...let me see if I can remember which one it was!
Howard
www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
If you’re referring to splicing into the ignition control circuit of an individual coil - this would yield a 1 ignition pulse per 2 engine revolution output. This type of signal might be compatible with an aftermarket Tach - not sure about cylinder mode setting of the Tach (probably set to either 8 or 4 cylinder mode).
Regards,
Taz
EDIT: Recounted the ignition pulses (using all fingers, and some toes - think I got it right this time !)
