I am having fits with this, I am seeing on the non RR PCM's and RR PCM's.
But if I flash my RR with a cal, at first it worked fine, then I flashed to another, and now the PCM won't boot up.
I am having similar problems trying to fix someone's PCM using a bench flash programmer and soldering the part back on the board.
I have a couple PCM's now that won't boot, they were flashed with a corrupted .bin I think, so I pulled the flash and reflashed with what was given as good code (Ross sent to me), and still it won't boot.
So I pulled my 03 truck PCM off the shelf that is modded for my RR, and tried it with 03 LM7 code, and worked fine. Then I tried to change to 03 Av 2500 code, and now it won't boot the PCM, so I went back to the code that did work before, and it won't boot either.
I tried on my 0411 PCM, never got it work on that either.
I am quite confused why I have this much problem. I have used many different OS's on my RR in my 3800 L67 (varying years from 2000 to 2005).
Anyone have ideas? I saw a reference that Jesse said that the PCM can get in an infinite reset loop, but I can't find out what it is or how to interrupt it, and how to determine IF that is what is going on.
Thanks!
