Have dsp5 with some built trans tunes, Getting p0101 code maf, any help to resolve will be appreciated.
hi, when running more aggressive tuning you may have to tweak your maf settings, error times,but logging it would be a good start been there done that/ if you want send tune and i will take a look at it.
09 K2500 HD DMAX Z71 cc sb efi live Dsp5 tuned by me , banks ram air ,autometer gauges ,airdog 165, transgo jr ,pcv re route ,on 285's with air ride soon to come Gmax 6
I shut my P0101 off as I didn't feel like tweaking teh expected MAF table to correct for it. In over a year I have yet to have any adverse effects from having it turned off. Teh MAF still works for limiting max fueling and such, so I see no need to tweak it.
Thanks for the responses, went into C0904 and bumped it up this morning been good all day. no light.
also may want to set error time to max, should have been BO901 and relevant tables
I will check that out, thanks again
