There is a bug in the Jan 2015 pre-release firmware that causes black box logging to fail and that prevents wide band O2 data from being logged.
You can however, use the: F1 Scan Tool -> F2 Data Logging -> F3 Display WO2 option to view the wideband data.
When viewing the wideband data, press [Back Space] to cycle through the wide band types until you get to the correct one.
As soon as its available, updated firmware will be posted here: https://forum.efilive.com/showthread...e-and-firmware
