Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
Thread: AEM wideband to FlashScan V2
  1. #21
    68problemchild,
    see this thread, try swapping Rx with Tx:
    JAW-Wideband-serial-connection&p=143297#post143297
  2. #22
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    So if using the RJ14 (6 position) plug to V2, which position goes to TX and RX? Positions 1 (black) and 2 (red)?
    I believe a white wire goes to position 5 on the RJ14 plug. Not sure if this comes into play.
    I can call AEM and find out which wires are TX and RX respectively on the AEM unit itself.
    Thanks.
  3. #23
    Yes, pins 1 and 2 on the RJ12 plug.
    Pin 5 is ground, you need this.
  4. #24
    Nov 2006
    The AEM directions call for the GRAY wire to be connected to pin #2 of a RS-232 DB-9 connector.
    The cable that comes with the V2 has a DB9 end and an RJ-11 end.
    db9__rj11
    _2 <-> 1_Rx
    _3 <-> 2_Tx
    _5 <-> 5_Signal Ground
    LC-1 WBO2
  5. #25
    Related thread (which I had forgot about): showthread.php?15748-AEM-compatibility
  6. #26
    Jan 2011
    hello,
    I have the same problem
    the display show W02 NOT FOUND
    ii have tried every wire combination and still no luck, the sensor is grounded, my yellow light is flashing, the green light on the UEGO controller is on
    im lost
  7. #27
    Quote Originally Posted by derkscustomcars View Post
    hello,
    im lost
    How did you connect it...?
  8. #28
    Jan 2011
    serial out from AEM UEGO module, grey wire, to RS232 on Flashscan, i tried both pin 1 or 2 of the RJ-11
    Brown wire to #5 of RJ-11 and to vehicle and ground
    Power as per AEM manual. I have tried the ground wire any way, just to RJ-11, Just to vehicle ground, not hooked up etc
    The yellow light on the V2 flashes as there is something going on, but nothing.
    I set up the Flashscan with Efilive Scan and Tune version 8.2.1, build 170. i went through all the settings, like i said, im lost
  9. #29
    Connect like this:
    AEM grey wire -> RJ11 pin 1
    AEM black wire -> RJ11 pin 5
    The black wire also goes to vehicle/battery ground.
    Do not connect the brown wire to anything (at all)(tape it off);
  10. #30
    Jan 2011
    Thanks, But i'm pretty sure i tried that, i will give it another try
    by black you mean the sensor negative that comes in the bundle of wire? white (EUGO 0 - 5v) , Brown (analog -) and Grey (RS232) or do i run a separate ground wire and just use only the
    grey one out of the bundle?
    I have AEM Part number 30-2310
    Thanks again
  1. Help connecting AEM wb to flashscan
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2011, 10:14 PM
  2. aem wideband vs. innovative lc1
    By badls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2010, 07:58 AM
  3. pids for AEM wideband
    By blazinblue in forum FlashScan V2
    Last Post: April 22nd, 2009, 04:04 PM
  4. How to hook up AEM wideband to interface? help
    Last Post: October 11th, 2008, 06:16 AM
  5. AEM wideband gauges
    By madprof01 in forum External A/D inputs
    Last Post: June 5th, 2006, 09:34 AM
