Results 1 to 10 of 12
Thread: how does the licencing work...noob alert
    Apr 2011
    Default how does the licencing work...noob alert
    hello all,
    i just purchased efi ver 2 from a reseller. i also just joined the forum today to try and get a bit of a grasp on what i just bought before it shows up. i have someone else doing my tuning, and will be learning as we go.
    however, how does the licencing work? i have 3 gm vehicles, 2 gasser trucks and one diesel, that i want to tune. is there licences that need to be purchased for each vehicle....? i know hp tuners u would buy credits for doing cars, how does efi live work in that sense
    thanks very much, and if anyone has any links that a newbie like me should read plz pass them along
    thanks
    brandon
    99 gmc sierra lq9
    2500 lmm gmc 2500hd
    Apr 2011
    and to start i put it in the wrong section, plz move if needed
    99 gmc sierra lq9
    2500 lmm gmc 2500hd
    Hi BG welcome to the forum
    EFILive licensing works like this: a flashing license attaches to a PCM serial number or to a ECM/TCM serial number pair.
    What are the model/year of each of your vehicles...?
    With HPT, your vehicles have to be the same year.
    Follow links in my sig (pertaining to gasser tuning).
    Apr 2011
    where and how do i purchase licences
    99 gmc sierra lq9
    2500 lmm gmc 2500hd
    Your V2 should already come with 2 licenses (each can do either of 1 PCM or 1 ECM/TCM pair).
    Additional licenses are obtained from the EFILive Online Store.
    Apr 2011
    perfect thanks for the info. thats great as the two trucks need programming now and the other can wait!
    99 gmc sierra lq9
    2500 lmm gmc 2500hd
    Apr 2011
    So if I have one engine computer, and I want to flash 5 different vehicle OS's to it (any 2003-2006 GM Truck), all this requires is one license, because I'm only flashing these files to one physical engine computer, right?
    Aug 2010
    Yes sir .. once the PCM / ECM / TCM is licenced - flash it as many times as you want, with whatever OS you want (as long as the OS is compatible).
    Regards,
    Taz
    Apr 2011
    Sweet thanks
    Quote Originally Posted by Jim_PA View Post
    Quote Originally Posted by Taz View Post
    Regards,
    Taz
    Yes, correct, exactly as Taz said, then you can flash in any PCM compatible OS any time... no new license required.
    For example, say you had boost and nitrous, you would first flash in an F-body 12212156 OS, and then flash in 02020005 (COS5)... all on your current PCM license (no extra licenses, no extra cost).
  1. Replies: 4
    Last Post: June 25th, 2010, 04:08 AM
  2. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  3. Az Noob
    By azcatfan in forum Lounge
    Last Post: November 25th, 2007, 08:51 AM
  4. New Here = noob
    By blazinblue in forum Lounge
    Last Post: October 25th, 2007, 06:18 AM
  5. Noob Help Me Please
    By Dennis93TA in forum FlashScan V2
    Last Post: June 27th, 2007, 11:28 AM
