Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Load Percentage PID/Calculated Value
    Wow, there are definitely a few more params available in there.
    What does A.E. stand for? Like Delta MAP A.E. Multiplier Vs. TPS.
    I would like to see some of the first 9 in the second image (starts with % Vol Eff Vs. RPM vs. Load, only the single fire tables). Would like to see what the Mountain mode references are, never heard a reference to that before.
    Thanks Mike, appreciate it!
    Wish TC was like EFILive and you could look at tables without buying it. Plus I think you have to buy it through JET now anyway.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    I bought my TC through Moates, but I am a Roadrunner owner, so I am elegible for the program. If you don't want a Roadrunner, your only options are Jet (customer service sucks from what I hear) or Wester's Garage (not sure of them, mainly 6.5 diesel, but does cars too). Mainly went for TC because it is more cost effective for my shop when doing gear changes, tire size changes or the occasional 'farm or off road' cal for a 250,000 mile farm truck. I still use EFI Live for any serious tuning, as TC has no scanner or RTACS or anything of the sort! I am guessing AE is acceleration enrichment, cant tell for sure as there is no help file for this cal. . Looks as if mountain mode is off, I included it. but doesn't look as if it is on!!
    If you need more screenshots, let me know!!!
    Mike
Name:	LL8 tables.JPG
ID:	10464Click image for larger version.
Name:	LL8 tables2.JPG
ID:	10463Click image for larger version.
Name:	LL8 tables3.JPG
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
  1. Fuel_Economy calculated pid?
    By Zeus in forum General
    Last Post: June 3rd, 2013, 04:23 AM
  2. Formula help for Calculated Pid
    By vetteboy2k in forum Black Box Logging
    Last Post: December 21st, 2012, 10:16 PM
  3. Calculated PID's
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2007, 09:55 AM
  4. Calculated PID Problem
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 09:44 AM
  5. Can't get calculated PID to work for MPG
    By PSWired in forum General
    Last Post: August 7th, 2005, 07:29 AM
