Results 1 to 9 of 9
Thread: Finally have the truck back... New COS #3, one problem
    Jun 2005
    Default Finally have the truck back... New COS #3, one problem
    Hey guys,
    I finally got the truck back after the hit-n-run, and installed the 2/3bar custom OS (#3). All went well with the conversion (except the silly PLX wideband appears to be fubar) but I have no LTFTs -- nada. I followed the pdf directions explicitly and stopped at the "pseudo open loop" page. Since my WB02 is loopy, I'd like me LTFTs back on for peace of mind...
    Any idea where to start? The only think I did was follow the directions to disable LTFT learn at idle.
    Hello, my name is Erik and I am a horsepower addict...
    Quote Originally Posted by turboberserker
    Hey guys,
    LTFT will not work with Custom O.S #3, the price you pay.
    What is wrong with the PLX?, I have found them to be very reliable.
    Jun 2005
    Not really sure -- it worked like a charm until it sat at the body shop for 3.5 months.
    It passes all their engine off tests with no problem, but once the ignition is on, it either shows lean (even with the AFR commanded to 9.0 and the truck barely running from being so rich) or it bounces around wildly (LEAN->13.5->LEAN->17.2->14.5->LEAN->AIR->LEAN->12.0 etc). I guess I have to send it in. (oh and the narrow band voltages during all this are normal).
    If LTFTs don't work with COS #3, how is it going into closed loop? Or is it not really hitting closed loop anymore?
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Eric,
    In COS3, You need to get your VE inline to keep your fuel accurate when commanding anything other then 14.63. If you command 14.63 in {B3647} The PCM will use STFT and the o2's to keep the fuel in line. It's kind of a semi closed loop setting.
    Also, when you Autotune, you need to make sure you use 14.7 in {B3647} so the O2's aren't trying to correct the fuel, and you will get accurate maps. Its a little detail that really isn't in the tutorial for COS3 guys, that I had to figure out.
    Jun 2005
    Quote Originally Posted by kbracing96
    Eric,
    Crap... hehe just tuned for 2.5 hrs with 14.63 from 0-4000rpm 20-75kpa lol. I was wondering why they were all 1.00 or 1.01...
    14.7 for all rpms and kpa? Sounds risky at high rpm / kpas...
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Talking
    You can set the AFR to anything you want except 14.63. That is the only time it will go into the semi-closed loop. At least that is what I understood.
    I have never put mine back to 14.63. I check my BEN's all the time.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Lifetime Member MN C5's Avatar
    Mar 2005
    You can command a lower AFR than 14.7 to tune with.
    Jun 2005
    Yeah, in the light of morning it made sense
    Sep 2005
    Ya, I did the same thing Eric. I have mine set to ramp down to 11.5 at 100 kPa 4200 on up and it keeps it dead on all the way up. FWIW, I just drove from WY (4800 ft) down to Phoenix (1100 ft) and I did a autotune log down here and it was for the most part dead on with nothing being more then .02 off. Works pretty darn good if you ask me.
  1. Finally on track.
    By willn in forum Gen III V8 Specific
    Last Post: August 3rd, 2009, 12:44 PM
  2. Finally got my first crack at BBL
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2007, 12:22 PM
  3. 04 truck Efan problem using pins 33 and 42
    Last Post: September 5th, 2007, 02:42 AM
  4. Finally got my FS V2!!
    By ScarabEpic22 in forum FlashScan V2
    Last Post: December 1st, 2006, 04:45 PM
  5. Finally got the Dyno up and going!!!
    By Danville Performance in forum Lounge
    Last Post: September 20th, 2006, 04:59 PM
