Results 1 to 4 of 4
Thread: DTC error codes
    May 2009
    Default DTC error codes
    I'm having issues with my trans taking off in 2nd or 3rd gear at the strip, i was wondering if EFILive can turn off or change to not report DTC codes po722,po757,po751. Thanks for any info. 2005 GTO, 4l65 auto.
    Kevin
    Yes it can.
    May 2009
    Yes it can.
    Thank you, I guess my next step is to find someone in the area to tune those codes out, thanks again.
    Kevin
    May 2009
    I found someone to make the changes this coming Monday, hopefully in works.
    Kevin
  1. Dtc 040 & 041 ?? EGR codes...
    By Nor-Cal Nick in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 12th, 2014, 01:21 PM
  2. Replies: 2
    Last Post: June 2nd, 2010, 06:44 PM
  3. Replies: 1
    Last Post: June 2nd, 2010, 04:56 PM
  4. Error Codes?
    By hyper24 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2009, 12:08 AM
  5. Error Codes
    By Chevy366 in forum FlashScan V2
    Last Post: November 28th, 2007, 04:22 AM
