Results 1 to 4 of 4
Thread: Converting a HPT to an EFI Live file?
    Jun 2010
    Default Converting a HPT to an EFI Live file?
    Is it possible to convert a tune done with HPTuners to one for an EFI Live OS?
    I can get a tune that is near perfeect for my car but it is done with HPTuners and I only have EFI Live software on my laptop. I'm reallly just wanting to use this tune as a base so I can get the car running and then I'll be getting it fine tuned on the dyno and the track.
    any advice is greatly appreciated
    Oct 2004
    Strictly speaking it is not possible to convert files; neither software application can recognize the others file format. The only way you could potentially do something (and this assumes that the HP Tuners tune is not one of their Custom Operating Systems, and that the ECM remains unlocked) is to have the HP Tuners calibration flashed into your ECM and then read it out with your EFILive.
    Andrew
    EFILive Crew
    Jun 2010
    Thank-you for your response.
    Is there a way to know if the ECM is unlocked and it's not a custom OS? Or is it basically, try and find out at this point?
    Oct 2004
    Typically a stock ECM OS number will begin with a 12xxxxxx number. Commonly a custom OS will begin with some other sequence which is the most obvious indication that it is not a stock OS. However because you cannot load the HPT file in EFILive you may not know this OS # before it is installed. Equally, you can't really know if it will be ECM locked either.
    I guess as long as the person using HPT is friendly if it does turn out to be a Custom Os or locked they can revert to the previous calibration for you.
    Andrew
    EFILive Crew
  1. EFI Live File Section - Share your tunes!!!
    By Black02SS in forum Please Read First
    Last Post: March 11th, 2024, 11:39 PM
  2. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 09:42 PM
  3. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2010, 12:46 AM
  4. can anyone convert ant hpt file into efi?help,help
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: December 19th, 2009, 09:10 AM
  5. main differences from hpt to efi live
    By boostedyards86 in forum Gen IV V8 Specific
    Last Post: September 11th, 2009, 09:42 AM
