Gentlemen,
Having a issue to getting the CASE relearn procedure to activate. Started engine, monitor through dashboard until the minimum temperature was reached, P/N switch activated, foot off brake. Click on DVT link, Click the activate button as described in the procedures for the V7 SW. Should come up with another screen, showing rpm, tps position, etc? The window does not pop up as described in the instructions. No alarm telling me start the procedure as well.
I am using the V2 scanner with the lastest update ( passive pass through) along with the EFI live7.5.6
This is on a engine/pcm swap in my Camaro.
No codes are present that would keep the procedure from running, except for the P1336.
Am I missing a piece of the puzzle here?
Thank you for your help in advance.
Leonard
