Thread: CALC.PID for E38?
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default CALC.PID for E38?
    I haven't had much luck finding, nor making a PID that reads out MPG like the LS1 CALC.MPG does. Again, this is on a E38 controller.
    Can anyone point me in the right direction?
    Sam, post your calc_pids.txt file.
    Oct 2008
    Here you go
    BTW: you need to add at least 2 blank lines at the end.
    Code:
    *CLC-00-020
    MPG                0.0         100.0      0.2  "{SAE.VSS.mph} / ({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250)"
    Which of the referenced pids is not available for E38...? Is it GM.IBPW1...?
    Oct 2008
    Thanks for the tip on the calc.pid.txt Joe!
    GM.INJFLOW.lbpm is invalid for some reason. Tried on 2 different computers just in case. GM.IBPW1 works perfect just like the LS1 controller.
  1. Can some help me with a calc pid please.
    By pavetim in forum Diesel
    Last Post: February 4th, 2011, 01:17 PM
  2. calc.pid help
    By mr.prick in forum General
    Last Post: June 1st, 2010, 02:28 AM
  3. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  4. Calc.PID question
    By Elowe65 in forum Diesel
    Last Post: March 5th, 2008, 04:52 PM
  5. hp calc PID
    By pwilson22000 in forum General
    Last Post: July 25th, 2006, 12:58 AM
