Anybody have issues with the new updates of V2 connecting to your LC-1? I just got another LC-1 and it connects to my laptop but my V2 isnt' showing that it's connecting. I just upgraded to the newest versions of the V2 also.
Funnily enough I just installed my LC1 today and connected it to a fully updated V2 with no issues using 3 paperclips as a null modem converter!!!
Tim,
Which version of V8 software...?
Using the V8 S&T program, you have to edit the Device settings to set serial comms for Innovate wideband.
And you do need the null modem conversion.
Check the V2's internal settings to see if Innovate is selected for serial WO2.
TAQCables sLC1
LC-1 WBO2
I hooked it up to truck and ran fine but with v2 hooked to laptop ot didnt work, wierd
When you connect the LC-1 to the laptop, remove the null modem adapter.
It connects to laptop it dont connect to my v2 when my v2 is connected only to laptop
So your problem is with passthru?
LC-1 WBO2
