(This is my 12th E38 Harness I have built with No Problems on the previous 11)...
I built a E38 standalone harness for a 2007 5.3ltr engine(58X GEN4) using a TH350 transmission...Brand new wires & connector's. I plug everything in, hook up power-ground-ignition & as soon as key is switched on can I hear fuel pump prime for 2 seconds & I can hear throttle body receiving power because it opens & closes quickly.... Injectors, coils & maf sensor all have power. I press on electronic pedal and nothing happens, I check power again & everything is fine!!! I took apart both connectors at computer & check all pins & locations & checked continuity for every wire & pin 10 times and everything checks out perfectly...So I plug in V2 into OBD2 port & with ignition ON I get "ERROR-VEHICLE NOT DETECTED" ...Checked pin location & continuity for High Speed GMLAN data bus (+ -) PIN's 27-28 both check out OK! Checked ground on PIN 73 and also checked power at computer on PIN'S 19-20-47 all 3 pins have power with ignition ON.. I check-recheck-check again-check again-recheck again & nothing!!! Next I pug ECM into Bench Harness & V2 connects just like normal & I notice I have 8 DTC's and they all have to do with Throttle Body & Electric Pedal, so I check connector's at TB & Pedal no damage & pins at connector aren't bent or anything. Verify that both pin location at connector match location on ECM connector & perfect-checked continuity too & checks out fine.....
I tried clearing DTC's on bench and they will not clear, I've tried it 5 times with no luck. Why will the Throttle body & Electric pedal DTC's not clear? Maybe this is my problem...but no matter what I do DTC's will not clear on this E38 ECM...
