Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: COS 5 Help Needed Here...Please
  1. #41
    Good to hear it is converging
    Log the pid GM.TRQENG... it should be high when any significant load is applied... the trans pressure is calculated/looked up from calculated torque.
  2. #42
    Senior Member tatasta's Avatar
    Mar 2009
    Idle is alot better. Once the car is driven around, it runs great. After I park for a while and restart, I get alot of surging. Not sure what the problem is there. It seem to heat up a little under light loads (coasting). I think timing is a bit far advanced. It is running around 32-33* at 2000-2200 rpm and light load. I can fix that.
    As far as the trans goes, the TFMPRS is hitting 90 at high TPS. I think that is good. Any trans help would be appreciated.
    I have lost some boost. Max MAP on this run was ~127kpa vs the usual 135kpa. I need to go through and re-torque clamps and check drive belt tension.
    Anyway, any guidance would be great!!
    Bob
    1999 Trans Am - P&P LS6 Heads - TR224-112 - Procharger P1SC - Performabuilt Lvl 2 4L60E w/ 2800 Billet Stall - 9" Inch w/ 3.70s - LS6 Intake - Mac Mids - ORY - Gibson Catback - Suspension, Drag Radials, A bunch of Other Stuff
  1. First time user, help needed flashing COS
    By jhinchy in forum Custom Operating Systems
    Last Post: December 10th, 2010, 12:47 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Help Needed.
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: January 9th, 2008, 09:31 AM
