Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: COS 5 Help Needed Here...Please
  1. #21
    Nah... it's just confusing at times.
  2. #22
    Senior Member tatasta's Avatar
    Mar 2009
    Quote Originally Posted by johnv View Post
    RE the trans,
    I would put some torque reduction back in on your 1-2 shift (DO801),
    and maybe lower the shift RPM on the 1-2 shift (DO940) to give the trans more time to complete the shift.
    can you post your std tune file so we can compare and see what you've done.
    Yes. Tune 009 is the starting point. Tune 010 has a few changes to the VE tables.
    Also, thank you for the feedback on the trans issue. Are you referencing the D1108, D1109 and D1110 tables?
    1999 Trans Am - P&P LS6 Heads - TR224-112 - Procharger P1SC - Performabuilt Lvl 2 4L60E w/ 2800 Billet Stall - 9" Inch w/ 3.70s - LS6 Intake - Mac Mids - ORY - Gibson Catback - Suspension, Drag Radials, A bunch of Other Stuff
  3. #23
    Lifetime Member johnv's Avatar
    Jan 2005
    Starting to get there, not tracking to bad out of boost, but still very rich over 115kpa (2 psi boost)
    I've taken some fuel out of boost VE table and made a few changes to trans in attached file.
    Can you log "idle air control position"
    Do you have the std factory tune file ? Flash it in (calibration only)and read it, save the tune (this will save it as a COS so we can compare all the changes that have been made)
    Then go back to your current tune file.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  4. #24
    Mar 2009
    Here is a log based on your last file. I also dropped the VSS and RPM shift points but it is still shifting at too high of an RPM. Seemed better but still too high. The WOT AFR above 105kpa is better.
    Also, I logged the IAC steps. I was messing with the steps in the first 3000 frames so, don't mind those.
    Also note that the tune name has changed.
    Thanks for the help
  5. #25
    Jan 2005
    give this a go
    Back yard boost
  6. #26
    Mar 2009
    give this a go
    I will load it up tomorrow. Thanks for the help. Should I enable LTFT after this? I think my VE is getting pretty close.
    Also, should I lower my IAC counts vs tq?
    The car pulls pretty hard. I found a few areas that are pulling timing. Should I go back to a N/A type timing table and use boost timing to reduce?
    Thank you
    Robert
  7. #27
    Mar 2009
    give this a go
    Also, it appears that my speedo calibrations were off. I reloaded EFI Live to Windows 7 and looks like tire size etc were wrong after new OS.
  8. #28
    Mar 2009
    johnv,
    Log based on your last tune file.
    Running pretty good. Idle still pushing a little and shift RPMs still a bit high. I can work on those.
    WOT AFR getting pretty close. My timing is still retarding to 13* at WOT. What do you suggest to straighten up the timing? My target is 17* at WOT.
    Tune001 and log included
    Thank you for the help!
  9. #29
    Jan 2005
    I would leave trims disabled for now , and work some more on your VE tables.
    still running rich at higher boost levels and going rich on decelleration (did you load CAX file) if so reduce "minimum transient pulse width" to same as "minimum injector pulse width" in tune.
    Get the fueling as close as possible first, then start playing with timing.
    And yes, I like to use close to NA timing tables then use Boost timing table to pull timing down to safe level during boost.
    Back yard boost
  10. #30
    Mar 2009
    Well, WOT AFR is looking better and spark is getting closer. Can someone post the proper cax file minimum injector pulse width for COS 5 again? I can't for the life of me seem to get the cax file to work. I am lost on this.
    I lowered minimum pulse width on Tune 3 vs Tune 2 and lowered IAC steps. Idle is a bit better.
  1. First time user, help needed flashing COS
    By jhinchy in forum Custom Operating Systems
    Last Post: December 10th, 2010, 12:47 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Help Needed.
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: January 9th, 2008, 09:31 AM
