Ok. I got the cax file in the right place, finally. The one I loaded has B9012 and B9014 but not B9021 so I will search around.
The last drive, when the car idles in gear, not moving at 0% TPS it idles around 880rpm. I can let off the brake and still at 0% TPS the idle will not go up even at 7-9 mph. But, as soon as I touch the throttle, the idle jumps to 1250rpm and will stay there until I stop the car. I guess the question is whether it this is a pulse width problem, airflow problem or a problem related to what the VSS is reporting.
If I could get the idle, I would be pretty close.
